0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 27 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 27 | I think I’ve done my research and am not asking a question that’s been answered over and over - but if I missed something I apologize. Dealing with the age-old RH-5 question on my 1950 6400. Backs are widow makers fronts are not. Has anyone found a useable adaptor to take 4.75 x7.25 pattern out to 10.25? My son is a CNC machinist and we’re preparing to make our own - but I’m wondering if anyone has come across an off the shelf option. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Don't know of anyone making them, however the correct wheels are way better than adapters, steel or 7000 Al would be the best to make them from.
Ed
| | | | | Joined: Mar 2017 Posts: 27 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 27 | I agree on the correct wheels, but seem to be unicorns from everything I see on here and elsewhere. I don’t load this truck real heavy, but I enjoy it and use it a lot and need to come up with a solution - present tires are 40 yrs old and in dire need of replacement. We’ll make any adaptors out of good steel. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | New Guy,
Not sure what your existing pattern is, 4.75 x 7.25 doesn't make sense, usually the first number is the number of lugs, the second is the diameter, i.e. 10 on 7.25" for example.
I made some steel adapters to put original IHC 5 on 8 wheels on a D 70. 1" or so steel, drill and tap 8 on 6.5" for Allen bolts from inside of axle, bore ID of adapter to fit Dana hub, drill and tap 5 on 8" for stud centered IHC wheel. Been working fine for 10 years or so.
Ed
| | | | | Joined: Sep 2018 Posts: 21 diesel weasel | | diesel weasel Joined: Sep 2018 Posts: 21 | He has it written as pilot hole x lug spacing, I can only assume he has 5 lug fronts and 10 lug rears.
Sharp knives Accurate Rifles Smooth Whiskey
If what you have is 5/10 on 7.25", late '50's first tubeless tires had 9 x 22.5 tires, mostly found on farm trucks that should work on your truck. The rims are sort of narrow, but mount a 9" tire OK.
If that is what would work for you, don't bother calling around wrecking yards, they won't know what you are talking about, and if they think they are rare(they are) , they will charge too much. Look around junk piles, abandoned scrap piles, many farmers and ranchers have those.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Those tubeless 10 lug on 7.25" wheels actually came with 8x22.5 or even 7x22.5 tires. These sizes likely aren't available any more, I haven't seen theme except old crispy tires on these wheels. The available replacement is a 9R22.5 tire, which should be used on 6" wide rim minimum. The old wheels are only 5.25" wide, the 9R22.5 tires do still easily fit and in many cases will work fine, but not advised by the tire manufacturer. | | |
