3 members (Pete1946, Steelonsteel, Otto Skorzeny), 239 guests, and 16 robots.
Topics128,077
Posts1,056,032
Members48,433
Hello Bolters,
The Door hinge spring on the driver's door is broken.
I now have a replacement.
My question is does the door have to be removed or can it be replaced pulling the hinge out ? Thank you for any direction in this fix.
Todd
I ran a "search" but really did not address this issue.
1950 Chevy 3100
Yes, You'll need to remove the door to replace the spring. Some guys have used a trick of drilling and pinning the hinge location on the door itself, but If you're rebuilding hinges, they'll probably need to go back in a slightly different position.
