1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,228
Members48,436
#1285967 11/03/2018 9:55 PM
Does anyone know of a vendor that sells a brake line kit for a 1949 Chevy 3800 Cab/chassis? I'm looking to replace mine to ward off any future issues. Not sure if there is any internal rust, but don't want to gamble. And I'm not sure I want to trial and error teach myself how to bend my own lines. Thanks!
If you decide to make your own use copper nickel lines, very easy to work with. If you already thought you might could make them then I’m sure you can do it with copper nickel.
•1952 Chevrolet 3800 pickup
---All pictures---
Fox Offline
If you do bend and make your own lines, get a quality double flare tool. It will save you A LOT of aggravation and cursing.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Another vote for copper nickel. Bends and flairs easy. It will work harden but is much more forgiving than steel. Making up lines is really pretty easy. You have the originals for a pattern and it's usually possible to reuse any brake-line blocks, just be sure and get new fittings (and remember to slide em onto the new line before flaring, don't ask why I say this). Good Luck, RonR
RonR
1970 340 Duster
1964 CJ5
One of the selling points is it does not work harden.
---All pictures---
Fox #1286207 11/05/2018 3:39 PM
Suggestions on the best and most inexpensive place to obtain one? Good brands that will do the job w/o creating more problems and frustration AND not break the bank? A quick google was showing sets upwards of $300. I could pay for a pro to do it if I was going to buy that tool.
On another thought... any suggestions on cleaning/reusing my existing lines? Initial thought was to replace, but now I'm thinking a rehab may be route I go.
Go with your initial thought - replace.
See what people cost for a "tool set" that is the minimum set needed for your job.
Crusing in the Passing Lane
Steel brake lines rust from the inside, too. Ed
Without putting a very tiny camera in the lines, there is no way to tell if they are badly corroded inside. I am casting another vote for copper nickel lines. I used them and they seal easier too. The problem I had with th cheap flaring set was that the clamp was not strong enough to securely hold the line in place. The more expensive tool does the job.
1951 1 Ton Completed
You possibly can “borrow “ the tool from Autozone or O’Reilly auto parts stores.
Eastwood sells some good brake line tools. You will need a double flare tool, a bender and a tube cutter. They also sell the tubing & fittings, which can be bought locally.. https://www.eastwood.com/tools/brake-tools.html?limit=all
Fred
52 3600
69 C-10
Even your basic Imperial brand double flare kit with the little buttons will do the job, try to avoid the really cheap imported flare kits.
I've used the Easwood lever type flare kit and also a similar one form Fed hill, and one from Brakequip.
The Eastwood one is lower quality, the dies and blocks are not finished as nicely, it's still a functional tool.
Fed Hill was expensive, very functional. http://store.fedhillusa.com/flaringtools.aspx
Brakequip a good balance of price, quality, and also very functional, this is the one I have/keep and use regularly. http://brakequip.com/products/tools/flaring-tools/
---All pictures---
I know they corrode from the inside too. That's why I was leaning to replace. So, looking at the flaring tools, what is the typical die used? I see DIN, 37*, 45*....I know it depends on the fitting, but what is most common.
All you need for the original truck and any likely upgrades is 1/4” (possibly 3/16”) 45 degree double flare.
---All pictures---
Thanks as always Grigg!!
Another vote for copper nickel lines... It's even easy enough to bend and flare the lines from under the truck so you can have a really clean install that only you and your wheel guys will appreciate
1953 3100 Mariner blue (some anyway)
Jon, Don't be intimidated with making lines. If you have average mechanical aptitude you can accomplish the job. I am also in the copper nickel camp, the metal bends/flares way easier than other products. The real nice flaring tools exceeded my budget. A run-of-the-mill USA made Sears Craftsman flaring tool (~$40) has worked satisfactorily for me provided that the lines are clamped into the die REAL tight before you start flaring. Paul
Lots more pictures
