1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
Can anyone provide me a clear CLOSE UP picture of the placement location on the right side upper engine cowl for the aftermarket right side mirror arm? Thanks
Will
Best Regards
Will
Will,
Have you tried a search? I believe about a month ago someone actually posted a template I just don't remember where. Also this is not strictly an aftermarket item but factory options.
210G Mirror & Bracket short, RH $3.40 Installed
210J Mirror & Bracket long, RH $3.40 Installed
Here you go.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=004567#000000
Drew
None of the pictures show a 1951 3100 Chevy right hand side mirror mount? The mirror is supposed to mount on the right side engine upper cowl and not on the door.
The mirror bracket arm that I have is an aftermarket from "American Classic" P/N MI111 for years 1947-1955
Best Regards
Will
If you look up underneath of the dash on the passenger side you will see two holes that are punched for the bolts going through the inner sheet metal. You might have to remove the glove box to see them. A punch up through them will show you exactly where to drill. Good luck,
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Thanx Steve O, did it, mirror installed perfectly!
Best Regards
Will
