0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Can anyone provide me a clear CLOSE UP picture of the placement location on the right side upper engine cowl for the aftermarket right side mirror arm? Thanks Will
Best Regards Will
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Will,
Have you tried a search? I believe about a month ago someone actually posted a template I just don't remember where. Also this is not strictly an aftermarket item but factory options. 210G Mirror & Bracket short, RH $3.40 Installed 210J Mirror & Bracket long, RH $3.40 Installed | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Here you go. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=004567#000000
Drew
| | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | None of the pictures show a 1951 3100 Chevy right hand side mirror mount? The mirror is supposed to mount on the right side engine upper cowl and not on the door. The mirror bracket arm that I have is an aftermarket from "American Classic" P/N MI111 for years 1947-1955
Best Regards Will
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | If you look up underneath of the dash on the passenger side you will see two holes that are punched for the bolts going through the inner sheet metal. You might have to remove the glove box to see them. A punch up through them will show you exactly where to drill. Good luck, Steve O | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Thanx Steve O, did it, mirror installed perfectly!
Best Regards Will
