4 members (Otto Skorzeny, WICruiser, 55shaker, 1 invisible), 80 guests, and 6 robots.
Topics128,095
Posts1,056,072
Members48,433
#1285937 11/03/2018 4:42 PM
I have a replacement cam thrust plate and spacer from chevs of the 40’s
does anyone know if the spacer that has one beveled side goes towards the cam gear or does the beveled side of the spacer go towards the block
[img]http://http://s12.photobucket.com/user/drewbie65/media/Drew54/IMG_8959_zpst6oqcw2k.jpg.html?sort=3&o=0[/img]
Drew
1954 3104 3 window
I usually install the bevel toward the cam. Check to see if either the cam or the gear has a radius that the spacer needs to accommodate, but since the snout is on the cam, that's the logical way to aim the spacer bevel.
thanks Jerry
Drew
1954 3104 3 window
