1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 23 | I have a replacement cam thrust plate and spacer from chevs of the 40’s does anyone know if the spacer that has one beveled side goes towards the cam gear or does the beveled side of the spacer go towards the block
[img]http://http://s12.photobucket.com/user/drewbie65/media/Drew54/IMG_8959_zpst6oqcw2k.jpg.html?sort=3&o=0[/img]
Drew 1954 3104 3 window
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I usually install the bevel toward the cam. Check to see if either the cam or the gear has a radius that the spacer needs to accommodate, but since the snout is on the cam, that's the logical way to aim the spacer bevel. Jerry
