3 members (Nick in Manitou, TooMany2count, klhansen), 120 guests, and 4 robots.
Topics128,109
Posts1,056,240
Members48,437
#1276002 08/12/2018 10:58 PM
I have a 58 Chevy step van with a brittle rats nest of wires. Could someone recomend a good quality harness for a generator setup. I've seen prices from 100 to 500+. I would probably get the smallest, 8 circuit I believe. Thanks
1958 Chevy Grumman Olson step van
Chaz,
If your step van harness can be replaced with a pickup harness, Classic Parts' set at $199 should be a good one.
https://www.classicparts.com/Wiring-Harness/products/124/
That link also shows a few "cut-to-fit" kits.
Same quality/type harnesses are available from Jim Carter, Chevs of the 40s, and other old truck parts vendors.
Thank you sir.
You can save a ton if you buy 10 and 20 ft lengths of wire and do it yourself. It’s just too easy to pay for a wiring harness. I’ve got $80 in mine. I used wire with the correct tracer color. Was easier than installing the headliner. 😜
Don
Can’t begin to tell you how much I hate the name Stovebolt.
Insomniac
Insomniac
Don
thumbs_up
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I rewired by 56 from stem to stern with a harness from Lectric Limited. High quality and easy/straightforward to do (i'm an electrical engineer so my "easy" might not be anyone else's...)
I wanted to do mine in stages. So I removed sections at a time and made up new ones and installed on the same day. No down time. A full harness would overwhelm me. I also didn’t like the colors on the lower cost sets. But good on you.
Don
Is there a particular gauge wire that would work best for re-wiring most of the truck or would one have to buy some of each gauge? I want to re-wire my '58 as well but the amount of money for a harness seems insane, especially considering shipping, duty and $CAD to $USD conversion.
1958 Chev Apache 3600
I've got about $350 into a $99 wire harness that I built myself, it was fun and not too difficult. It did take a lot longer than I anticipated. Kits are much easier and faster than trying to build a harness yourself.
Another quality post.
Real Trucks Rattle
I used rebel wire for my 51 3100. If I had issue the support was great.
Chris
I built the harness for my 78 vette with wire from Waytek Wire. I spent about $300 to get all the sizes and colors I wanted, but only used about 25% of it. When I looked at it, the off the shelf harnesses were the way to go if you only wanted to do one vehicle.
If you do other work or want to mod the harness for whatever reason, getting raw wire and doing it yourself is not hard and lets you customize to your heart's content.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
