5 members (Shaffer's1950, Gdads51, Otto Skorzeny, Wayne67vert, Hotrod Lincoln), 96 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
I want to put one of these:
[img]http://BoltBucket.org/merlin/Rolls-Royce-Merlin-1602x1031.jpeg[/img]
in my '64 C20. But the only way I can envision pulling it off. Is by putting it in the bed,
and using something like an Olds Toronado transaxle as a rearend / axle for it.
Seem like a worthy project?
--Chris
'64 Chev C20 LWB stepside (Ol'Blue)
Crusing in the Passing Lane
The RR has way more torque than the olds trans. was designed for.
Ed
H Online: Content
Start with something like a military deuce and a half drive axle and have someone build you a gearbox to transfer the power straight down to the input flange. No need for gear reduction- - - -it will have enough torque at idle to slip the clutch and get moving. Reverse- - - - -you're really on your own there!
Torque? Who needs torque? Most all of them weighed in @ 12 to 16 hundred HP! smile
Tested for 35 hrs. @ 2,000 HP on "exotic" fuel.
I think you're on to something, Jerry. Reverse? Who cares. With that much HP I think I can pretty
much go forward, no matter *where* I need to go. smile
If I win the lottery, I think I'll put this project on my TODO list.
--Chris
Been thinking this over and here is what I would do---get BOTH engines off a P-38 and when you need to back up just swap out engines.
Evan
LOL but where to *put* that reverse engine. smile
--Chris
Lots of ideas here.
RonR
1970 340 Duster
1964 CJ5
@moparguy
Sweeeeet. I love it!
Thanks!
--Chris
Originally Posted by moparguy
Lots of ideas here.
Saw an episode of Jay Leno's Garage featuring that rig. Seeing it run was pretty awesome. yahoo
I saw that at SEMA last year he drove it to where they do the after show on Friday night pretty cool.
A bone stock trans-axle will hold up just fine if you use a planetary drive in the rear hubs. Our 4 engine 10,000hp tractor had a 9 inch Ford differential that held up just fine.
Evan
