Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (NJC, baldeagle, WingWright), 51 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#1285196 10/28/2018 2:47 PM
I have my great grandfather’s 50 GMC 1 ton sitting out back collecting snow and dust, sadly. It does run, but only gets used, if at all, in the summer to move firewood. I’d like to turn the truck into an every day driver and something that is safer on the road in all seasons. It seems like a much better investment of a good chunk of money to keep a family heirloom working hard in the family than to blow it on a modern plastic truck. Living in Wyoming, however, a 2WD truck can only get me so far.
My question is this; has anyone here successfully put 4WD onto a 1ton AD truck? If so, how? This would obviously also come at the price of an engine swap with new suspension, etc., which is what I’m looking for. I’ve heard of doing frame swaps and am not opposed to that at all. I just want to know where to start, or if someone has a better idea of how to do it.
Any help is much appreciated! Thanks.
WyoFlyer #1285244 10/28/2018 9:13 PM
Crusing in the Passing Lane
AD's must be raised to fit transfer case/driveline under the body. Look at what was done on '55 to '58's from the factory to get an idea. Front axle sticking out of fenders is a start on results.
Ed
WyoFlyer #1285255 10/28/2018 10:03 PM
Unless you’re using original NAPCO, Coleman, or otherwise period correct 4x4 parts that fit right and look appropriate I think you should stick with 2wd. Those front axles may have limited gear choices, making for a slow truck.
Otherwise as Ed point out it’s a lot of work and may not look that pleasing.
If the truck has been in the family for so long drastic changes may be a mistake, it’s only original once.
If you only swapped the rear axle for a 14 bolt you’d have faster gear choices and readily available Detroit locker, might get by with 2wd just fine. Read sticky thread about that swap.
1952 Chevrolet 3800 pickup
---All pictures---
WyoFlyer #1285264 10/28/2018 11:43 PM
Fair enough, thanks for the info guys.
WyoFlyer #1285322 10/29/2018 3:12 PM
I converted to a 14 bolt rear with a locker and it helped significantly in the snow season. Daily drove for 2 years (city and highway driving) with one instance we had with over a ft of snow, was parallel parked and able to get out without shoveling. Prior I couldn't even get out of iced over pavement.
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
WyoFlyer #1285419 10/30/2018 3:02 AM
Hey WyoFlyer, take a look at the Craigslist/eBay part of the Swap Meet section here on Stoveboldt. Interesting pictures of a '55 4wd GMC.
WyoFlyer #1285440 10/30/2018 12:01 PM
I've wondered about using a wagoneer dana44 front under one of our trucks. I think it would be narrow enough to look stock, but I haven't seen one done yet.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
WyoFlyer #1285515 10/31/2018 2:38 AM
Have to raise an AD pretty high to have the frame, etc., clear the front diff., spoils the lines.
Ed
Moderated by  Dusty53
