| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 57 | Had to replace the head gaskets, didn't mess with wiring anywhere. Battery shows 12.8 volts, Positive has continuity to starter. Negative goes to a main power switch in the cab and then returns to the side of the block. Continuity there and it breaks when the switch is thrown off. Two grounds from the firewall to the heads. All alternator wiring is hooked up and solid. I have nothing, no lights, no ignition, zip. Does not seem to have juice to the fuse block in the cab with the ignition "on" At a total loss for a solution | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Battery Negative should go to ground.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | At the starter solenoid you should have the battery positive cable and another smaller wire attached to the same stud. The small wire may have a "fusable link" within a bulge, trace that wire up to the firewall or into the cab and see if you have battery voltage. If it has the fusable link and you have no voltage then I would suspect it burned open.
| | | | | Joined: Jul 2018 Posts: 270 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 270 | Hey, mac, I just had the same situation in August on our 1963 1/2 ton. All stock. Had cheap after market fuel pump fail, and after repairing it, ... No lights, ignition, etc. Seemingly unrelated to the fuel pump fix. Like you, I had voltage from the alternator. I eventually discovered the wiring goes through the firewall through multi- prong plugs, and I had to pull these and clean the contacts. Then I had normal juice! Hope this helps, good luck! I know I was pulling out my hair( not much left)
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2016 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 57 | Will try cleaning all the contacts...This was an old Farm Implement Dealer's hauler before I got it. There must be 20 rolls of electrical tape around all the connections. The starter has positive from the battery to the big stud, a 16 gauge wire to the positive side of the coil, and a third off a small stud to the firewall but it goes through a grommet and into the unfused on the fuse block. It seems all screwy and is not really like any wiring diagram I have found but it all worked before the heads were off. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You just have a typical wiring mess that needs redone. Correctly. Ground to main power switch?? No no no no no........... I agree with Gord, only add "directly" between the words "go" and "to".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | By "main power switch" I wonder if he's talking about some kind of disconnect switch. I've heard of such a thing being used as an anti-theft device. Also seen them on fire trucks, where you throw that switch and it kills all power to the vehicle. I have a disconnect on the negative post of my F-350, since it tends to drain the battery if left unused for an extended period of time. | | | | | Joined: Feb 2016 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2016 Posts: 57 | Should have been a little better description...Rich is correct, it is a main power "Kill' switch. Just like he said. Direct from the negative on the battery to the "Kill" and then out to the block. There is nothing else in the circuit. I have to work on this mess outside an it is supposed to be decent today so I will grab my meter and start cleaning and checking positive connections. Let yah know when (if) I find the magic bullet.
Try putting the foam inserts into your hat, see if that helps.... ...then let me know 'cause I can't find my hat.
