8 members (Otto Skorzeny, Bill Marlow, HandyAndy, GRNHydra, 49nut, Wally / Montana, cmayna, 1 invisible), 256 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#1283821 10/16/2018 2:04 PM
I have been getting some parts off a 52 half ton frame that was broken in multiple places. I have another member interested in the spindles from this one. This pickup came out of an old junkyard and had been sitting for years. I ended up removing the cab, front clip, and engine and transmission. Differential was stripped out and I found the frame was busted up bad so ended up removing everything. Anyway I started to disassemble the front axle yesterday after getting it into my shop. The RF brake drum wasn't on all the way and seemed loose. I removed the drum from the left side and found the ball bearing assembly as the manual shows. BUT on the right side there are tapered roller bearings?? Why would these be on that wheel? The roller bearings are thicker so am thinking that is why the brake drum wouldn't quite go on all the way. Wonder if this was run this way? Anyone ever seen anything like this? Thanks
Last edited by Justhorsenround; 10/16/2018 3:04 PM. Reason: Remove all caps in title
52 6400
50 3600
69 Ford LTD
Riding in the Passing Lane
Roller brgs. are available for those but need to all be replaced at the same time. The ball brgs are expensive so someone just cobbled in a roller brg. to get by. You wonder about what is out there on the highway going 70 MPH bumper to bumper.
George
1972 Chevy c10 Cheyenne Super
Yes makes you wonder. My 2 ton actually had one of the tie rod ends held on with wire, I drove it 80 miles home from the auction and about you know what when I saw that. That was one of the many things I had to fix.
52 6400
50 3600
69 Ford LTD
The guys are correct. The original ball bearings lasted for years but have gotten expensive. You can purchase a complete front set of roller bearings with races and the seals for under a 100 bucks. I have a new set on my work bench right now waiting on the time to put them on.
Note: Some, I say some, not all, have had to polish the spindle a little to get a new roller bearing to fit on but it seems to be the exception and not the rule so don't be afraid if you get a set and one of the bearings is to snug. Get some polishing paper and in a couple minutes you will have a nice neat tight fit. .....now you won't be surprised if it happens to you.
My technique: freeze the spindle, heat the bearing (not too hot, dummy!). Drops on then sets firmly.
1951 Chevy Panel Truck
