4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1246299 12/09/2017 7:05 PM
I've fitted some new door seals to my 56 3100.The drivers door is now really hard to shut without slamming it.I tried adjusting the hinges a little but made no difference.Passenger side is ok
Stooby,
Since I am not there, it is hard to see exactly what you are seeing. But, I have to say, after installing the new door seals, in my 53 3100, they are considerably harder to get to shut. If your old ones were worn out, you probably got used to the way they shut. It is quite a difference between brand new ones and old ones. They do seem to get easier as the seals get pressed together, from the door being shut. Also, if the windows are up, it more difficult. I know that these trucks are far from air tight. But, letting the air escape out the windows, when you shut the doors, helps quite a bit. At least, it does with mine. Perhaps there are some more adjustments on a 56, than on a 53. If you want the door to fit flush with the cab, you just gotta, get aggressive shutting the doors for a while. Hope this helps. Maybe somebody will chime in, that has a 55-57. They very well may have a better answer for you.
Good luck.
Rugo
Steve Rugg
53 3100
Rugo #1283627 10/15/2018 12:02 AM
Insomniac
Insomniac
Originally Posted by Rugo
Stooby,
Good luck.
Rugo
Just installed new seals and to get the doors to latch requires pushing/slamming. Slammed it so hard, the door lever and window winder fell off onto the floor (should have tightened the set screws dang). This is from the out side. Closing from the inside won't be easy.
Question: how long did you have to wait until the seals conform to the body and things get easier?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord, do what I do. Adjust the door striker outboard of the current position so that it will close without slamming, yet still compresses the seal somewhat. The door edge will be slightly proud of the door opening at the rear. That's OK for now.
Over time, the rubber will lay down and behave, then you can move the striker inboard and the door will close without slamming, and be flush with the door opening.
This has worked for me every time.
Carl
Insomniac
Insomniac
Thanks, Carl! Appreciate the advice. thumbs_up
Gord 🇨🇦
Went through this on my 53, do what Carl says adjust the strike out until it breaks in about six months or so for me, then adjust in to align the door with the body.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Insomniac
Insomniac
Six months - great - it will be ready for next Spring!
Gord 🇨🇦
