1 members (1 invisible),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,059 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | I've fitted some new door seals to my 56 3100.The drivers door is now really hard to shut without slamming it.I tried adjusting the hinges a little but made no difference.Passenger side is ok
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Stooby,
Since I am not there, it is hard to see exactly what you are seeing. But, I have to say, after installing the new door seals, in my 53 3100, they are considerably harder to get to shut. If your old ones were worn out, you probably got used to the way they shut. It is quite a difference between brand new ones and old ones. They do seem to get easier as the seals get pressed together, from the door being shut. Also, if the windows are up, it more difficult. I know that these trucks are far from air tight. But, letting the air escape out the windows, when you shut the doors, helps quite a bit. At least, it does with mine. Perhaps there are some more adjustments on a 56, than on a 53. If you want the door to fit flush with the cab, you just gotta, get aggressive shutting the doors for a while. Hope this helps. Maybe somebody will chime in, that has a 55-57. They very well may have a better answer for you.
Good luck.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Stooby,
Good luck.
Rugo Just installed new seals and to get the doors to latch requires pushing/slamming. Slammed it so hard, the door lever and window winder fell off onto the floor (should have tightened the set screws  ). This is from the out side. Closing from the inside won't be easy. Question: how long did you have to wait until the seals conform to the body and things get easier?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Gord, do what I do. Adjust the door striker outboard of the current position so that it will close without slamming, yet still compresses the seal somewhat. The door edge will be slightly proud of the door opening at the rear. That's OK for now. Over time, the rubber will lay down and behave, then you can move the striker inboard and the door will close without slamming, and be flush with the door opening. This has worked for me every time. Carl
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Thanks, Carl! Appreciate the advice.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Went through this on my 53, do what Carl says adjust the strike out until it breaks in about six months or so for me, then adjust in to align the door with the body. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Six months - great - it will be ready for next Spring!
