6 members (WICruiser, baldeagle, Bill Hanlon, dt235sd, Stovebolt48, wilbur53), 123 guests, and 3 robots.
Topics128,038
Posts1,055,471
Members48,424
#1283558 10/14/2018 7:13 AM
Hello All,
I have a 1.5 ton (30CWT) 1940 Chevrolet truck. the battery is located under the right hand side of the floor. To access the battery a sheet metal lid with a hinge is lifted up.
My truck was originally built for the Australian Army, Then a farmer had the truck before me. Was the sheet metal lid in the floor a factory standard or was it a convenient modification for the Army mechanics or the farmer?
When the sheet metal lid it is lifted I can see some very rusty remnants of a possible batter. Two thick battery-type cables are hanging near the box.
Can someone with a similar truck please take some photographs and measurements of the battery box and post them up?
Is the battery box a part that can be bought from a Chevrolet parts supplier?
What brand of 6 volt battery do you use and what are the specification codes printed on your battery? As hinted by the very rusty possible battery box my truck did not come with a battery so I have nothing to identify a battery type with.
Kind regards
Lionel
Lionelgee #1283570 10/14/2018 12:27 PM
I am not sure of the Australian built (Canadian or Holden?) bodies, but the US made trucks of this era had the battery under the floor on the passenger side (left side is drivers side). Originally, there was no hinged door to remove the battery, but there is an access panel that can be removed to see the battery. Battery removal requires removing the floor panel. A hinged access would have been a great idea!
Lots more pictures
Lionelgee #1283574 10/14/2018 1:04 PM
Lionet,
Yes the BATTERY BOX is available.
Harold
Harold
Lionelgee #1283663 10/15/2018 8:03 AM
Thank you Paul and Harold for your replies.
Kind regards
Lionel
