6 members (Jay R, Phak1, Ponchogl, moparguy, tclederman, Otto Skorzeny), 88 guests, and 3 robots.
Topics128,128
Posts1,056,683
Members48,452
Hello Bolters,
I am currently working on the interior of my 1950 3100 truck. My question is where the floor pan meets the firewall (I think) , I can see light . Was this sealed or? It's right below the clutch pedal. About 8" or so. Any direction or advise would be great. The floors are in pretty good shape with small amounts of rust.
Todd
Thank you All. Repairs are in process & almost done.@@@@
1950 Chevy 3100
Typical to see the effects of rusting in this area. The floor is thinning, I had the same in my 53 and there were no other problems in the rest of the truck. Mainly caused from water trapped between the rubber mat and the floor and it progresses over the past 70 years.
Correctly fixed, it needs to be cut out and a new corresponding patch panel to be spot welded in, then primed painted undercoated. Band aid fixes can include wire brushing rust treatment primed painted and sealed.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock,
Is it ONE piece where floor pan goes up to firewall. To me it looks like two pieces come together and the seal is now gone? Hair line light coming through. Perfectly level, from left to right.
Todd
1950 Chevy 3100
Seal sealer is called for in that area according to the Factory Assembly Manual. Clean it free of dirt and rust, prime, paint , then apply seam sealer.
52Carl,
Thank you very much. What page # is that on? In the factory assembly manual?
I missed it completely.
Todd
1950 Chevy 3100
All I can say is look for it towards the end of the manual. That book is hard to navigate.
It would be far easier to see pics of what you are having to deal with, vs, description. 8" below the clutch pedal?
Craig
I sure don't find anything in the shop manual regarding this specific issue. In a couple days, I will pull back my floor mat to see what I have in my "green turd"
Craig
The OP sent me a pic and yes it's rot just above or below the firewall/floor panel seam. Looking at mine, I also have a little slit of rot in same area.
Craig
