| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Everything on my cab is finally sanded,scrapped & blasted. The epoxy primer is on. I was wondering. Is it better to overlap a patch panel or butt weld? Also would like to know if there is info on how to butt weld a patch? I plan to use a Millermatic 140 welder to do the work. Thanks | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | If at all possible, butt weld. But you can lap weld by forming a flange on the patch piece, inserting the flange under the panel and welding the seam. You can use welder's magnet to hold the patch even with the panel while you weld it. Here is some step by step patch repairs.... panel repair by patch welding I hope this helps Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks countilaw your photos are great and self explanatory. I like the Idea of creating a flange to use as backup for the butt weld. I have access to an air tool that is designed to create a flange. On a straight flat surface it seems to work well. I have just bought 2 rear cab corers and wonder before I try, if this tool will work around the curved contours at the top? Anyone have any experience using this tool? | | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | what do you mean by a flange? do you bend the metal over to give your a rounded corner to weld to? please let me know. thanks alot | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Vickraft...I've used a 2 hand held flanger tools(looks like a pair of vise grips) for creating flanges. One of them made a flange approx. 1 1/2" and the other was 1/2". The 1/2" worked very well for the rear cab corners due to the curve and didn't throw the curve out of shape. The 1 1/2' worked good for the straight pieces. Check out my webshots for photos of the rear cab corner flanges I made before I welded them on.
Hope this helped.
Have fun! | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I patched the door bottoms,rear and cab corners using all flanged joints. I used a air flanger and punch, about a half inch on width of flanger, which worked well. By flanging it gave me a little more room to adjust :hammering: the patch panels I fabbed up.  Take your time, weld in intervals and you will be OK. Pics below. Have fun. Dan http://rides.webshots.com/photo/1512695955071274430lWhMwv | | | | | | Anonymous Unregistered | | Anonymous Unregistered | There are clips you can get at Harbor Freight that hold the panels in place for butt welding. Either method will work but the butt weld is easier and quicker IMO. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The HF clips are 8 for 5$ which is a great buy, they provide a .040 gap in the butt joint and work with a thumbscrew, very slick and very expensive from other suppliers like Eastwood. I tig all my stuff and the weld in intervals and take your time is great advice no matter what method you use. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I decided to butt weld most of the things I have done so far. I use a piece of copper roof flashing folded over double as a backing and clamp it up very snug to the pieces being welded. In some cases when my weld pool is nice and flowing it fills the gap very nicely and the back side of the weld looks very very smooth. I use a MIG with some very fine wire. I think it may be .022. With the copper it helps with the heat too. I still get in too big of a hurry but it does help. I don't know as much as the others here but that has worked well for me.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | This is great information guys. After reading all your Ideas and tips I have decided to try my hand at butt welding. I have a list of things that I will have on hand when I do this. Go slow,patience,welders magnets, HF clips, copper roofing material as a heat shield (neat Idea) Also like Micheal I am using a Mig with a .022 wire.(gas shielding) First I am planning to practice on the same gauge of metal as the cab corners before attempting the actual repairs to my cab. Thanks again to everyone for the encourgememt. | | |
