0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Hi,I am attempting to remove the front cab support bolt so I can install a new cab support.I have removed the bottom nut and tried to place a jack under the vehicle and pushed up on the bolt thinking it would pop off,No such luck,So what am I doing wrong?Please help!! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | some have the bolt head tack welded to the floor pan | | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | I'm assuming this is the bolt that goes through the rubber body mount. I just did mine and had the same problem. There is a metal tube the bolt goes through ( inside the rubber) and the bolt is likely rusted into the tube making it a larger diameter than the hole in the floor. This tube is also probably stuck solid into the rubber mount. I used an impact wrench (alternately tightening then loosening) to break it free. I also was replacing the floor pans so air chiseled (carefully)the spot welds from the large "washer" the bolt drops through and then had to cut the bolt off after I got it out so I could re-use the washer.
Dave 66 GMC- father /son project with the "GMC KID" 36 Chevy PU- 4x4 lifetime project 64 Skylark- wife says its hers
| | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Thanks for the info Guy's,Oh yeah I also will be replacing a portion of the floor pan. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Howdy Ronald,
Did you get those bolts out yet? I had the right front one stuck on my 64. I am guessing that the moisture got down in there and rusted the sleeve and stuff together to the point it would not budge. I ended up getting a large drill bit and drilling down through the head of the bolt. Once I got though the head of the bolt that thing was a goner. The bit was about the same size of the bolt, so that let me chisile it the rest of the way off and was able to lift the cab off. With the cab out of the way I finnished if off with the hammer.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | hey Michael,No not yet,Been too busy with work this week {concrete foundations}.So I havent tried again.Maybe I can get to it this weekend.Thanks for the info.. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Yeah, that stuff called work has been cramping my truck time too, although I took a week of vacation just to work on my truck. At any rate I was pretty frustrated last week when I realized that the vacation was about over and I did not get 1/10 of the stuff done I had planned. Man this body work stuff goes so so so slow for me. Once I got all my metal work done, I spent at least 12 hours on one door.. Mix filler, spread, sand... sand... more filler, sand... Then on top of all that I still feel like it is not as straight as I would like. Maybe it is just my inexperience causing extra work. Anyway.. good luck.
