8 members (jmoore, TUTS 59, 1955 1 Series, Gdads51, Phak1, Woogeroo, DaveV, 1 invisible),
91
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | Its 5800 gvw and p-plate has 9 bolts holding to flywheel. I believe its the heaviest rated 3/4 ton that year. Also, I can't figure out what rear engine mounts i need. Engine is original 216 with 4 on the floor. I can't seem to nail the answers down using online retailers information. thanks 4 any help. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your nine bolt clutch will be 10 3/4" I believe. That is what is in my 1 Ton. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | Thanks Tim, I studied that link/page and started searching for 10 3/4" kit. Online retailers i been able to find seem only to offer 9" or 10". P-plate photos online seem to be generic 6 hole type. | | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | Your nine bolt clutch will be 10 3/4" I believe. That is what is in my 1 Ton. Did you replace yours? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | I'm finding 10 3/4" disc NA and Carter only 1 seems has 9 bolt p-plate. local clutch and brake place surge friction says wait till i change mounts. thanks 4 ur help. | | |
