2 members (Steveoreno, TPR57C), 106 guests, and 4 robots.
Topics128,186
Posts1,057,320
Members48,469
Its 5800 gvw and p-plate has 9 bolts holding to flywheel. I believe its the heaviest rated 3/4 ton that year. Also, I can't figure out what rear engine mounts i need. Engine is original 216 with 4 on the floor. I can't seem to nail the answers down using online retailers information. thanks 4 any help.
Your nine bolt clutch will be 10 3/4" I believe. That is what is in my 1 Ton.
1951 1 Ton Completed
Thanks Tim, I studied that link/page and started searching for 10 3/4" kit. Online retailers i been able to find seem only to offer 9" or 10". P-plate photos online seem to be generic 6 hole type.
Did you replace yours?
I did many years ago.
I'm finding 10 3/4" disc NA and Carter only 1 seems has 9 bolt p-plate. local clutch and brake place surge friction says wait till i change mounts. thanks 4 ur help.
