| | | Forums66 Topics128,084 Posts1,056,334 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Hi, On my 3600 I'm trying to install my rear hubs. Yet their colliding with emergency brake adjuster. No matter how much I adjust the emergency brakes it'll still collide. Now the rear of the hub is a sheet metal device used to guide leaks to the front of these hubs. I wonder if I can bash in the sheet metal enough to clear the adjuster. I believe I've attached a picture before I started adjusting the brakes and you can see that the first nut is just starting to thread on to the axle and I'm hitting the adjuster
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | There an't no picture Dag Gum It. I'm using a MAC and never had a clue.
Julian Carter
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So what I've decided to do is to remove the drip catcher from the rear of the Hub. This will only allow dripping into the emergency brake area where I can find it.
Julian Carter
