Hi, On my 3600 I'm trying to install my rear hubs. Yet their colliding with emergency brake adjuster. No matter how much I adjust the emergency brakes it'll still collide. Now the rear of the hub is a sheet metal device used to guide leaks to the front of these hubs. I wonder if I can bash in the sheet metal enough to clear the adjuster. I believe I've attached a picture before I started adjusting the brakes and you can see that the first nut is just starting to thread on to the axle and I'm hitting the adjuster
