1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those spring mount brackets on the rear axle housing are correct - they allow pivoting when the rear springs flex. https://www.chevsofthe40s.com/detail/8661/Chevrolet_Bushing_Bolt_With_Nut_Rear_End_To_Spring.html"These are bushings with bolts, nut. rear end pivot at leaf spring on a 1/2 ton pickup." The bolt that goes through the bushing is often hard to remove. Also, you might have to press out the old bushing from the cast housing, and then press/drive in the new bushing. | | | | | Joined: May 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 35 | Oh wow, that’s a relief to know. We’re all the half tons equipped with these pivot brackets? Looking at pictures online I was seeing them bolted directly to the leaf. Maybe I was seeing mostly aftermarket axles? Thanks for your help! | | |
