4 members (Gdads51, Rustnut, Otto Skorzeny, 3800GUY), 96 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
#1280936 09/20/2018 6:14 PM
Finally started on the '46. I've located a decent 235 and T5 and a 2005 Suburban 2500 rear end with a 3.73 ration. I'm going to be taking it in for sandblasting/powdercoating after I get the running gear off. I've been searching through some of the threads here regarding the rear end swap. Just about everything I've found pertain to '47 and later trucks. Has anyone changed out an original '42 - '46 rear end with a 14 bolt? I saw a link for the post '47 trucks that deals with an "offset" issue. Does that also pertain to pre '47 trucks?
Anything else I need to know before I begin the drive train swap?
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
Crusing in the Passing Lane
Depends on your rear end bolt pattern, need to match the front. Might need to move axle spring perches to fit your springs. Is your rear ff or sf? 3.73 might work well with T5. Make sure to match spring perch location and thus welding before powder coating.
Ed
Hi Ed,
The rear is a full floater.
Joe
Tearing her down
More images
Ed
Hi Ed,
I'm going to cut the old perches off and reweld them back where they need to be for my truck. This unit also has shocks that come with it. Would it be useful to use them? I haven't read anything about adding shocks to a '46 3/4 ton. I'm assuming it would be useful if I was carrying heavy loads but that's not likely. I'm thinking all that I need to do is construct an upper mount and weld it to a location that matches the location of the top mount of the shock.
Joe
Tearing her down
More images
Shocks are useful, especially on uphill gravel, washboard road with light load.
Make sure to weld new perches in loaded position.
Ed
Thanks Ed.
Tearing her down
More images
I've come across another rear end but this one has disk brakes. It's a great price and a 3.73 posi. If I were to use it would I have to figure out how to change the front to disks too?
Tearing her down
More images
No.🛠
