1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Got a 50 1/2 ton just put new wheel cylinders and shoes on it and the rear brakes gradually lock up after driving for 15-20 minutes. Front brakes are new also but work fine. Different type of adjustment on rear wheel cylinders, is there something I have missed on set up? Any advice appreciated---thks | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | They heat up and get way too hot both tire and wheel...wheel cylinders appear to have two adjustments on each side...why two? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Huck brakes...... special adjustment procedure. Require more attention than Bendix.ðŸ›
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Looking from the end of the wheel cylinder, turn the adjuster star wheel clockwise to expand shoes until you feel a slight drag, then back off 5 clicks. You need to do this procedure on both adjuster star wheels on each wheel cylinder.
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Anyone have info on a diagram (picture) on the components on the rear brakes shoes and hardware on the backing plate? I need to check to see if all is there and on correctly, someone else put these on this truck and the problem started. Also, thinking about updating to 51 Bendix system anyone done that? Thks! | | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Here's the diagram I used to put my '47 Huck brakes back in working condition. The diagram is for a 1 ton; however, it illustrates what you need for the complete Huck brake assembly. | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | You would need to replace the entire torque tube to swap to Bendix. The Huck backing plates won't work with Bendix parts, and the backing plates are welded on to the axle tubes.
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thanks for the info...I thought I could R&R the backing plates from one axle assy to the other but have not attempted it yet. I'm pretty sure that the hardware is not complete on the 50 rear axle brake system so that is what is causing the wheel cylinder not to retract back so the shoes still are applying pressure. Does any supplier have a hardware kit for the Huck system? If someone has a name I would love to have it. | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Looks like the main housings are the same for 50 to 51 later rear assys. I have taken them down to where the backing plates look like they will swap. Housing measurements appear basically the same and the 51 the plates unbolt where the 50 has rivets that will drill and be replaced with bolts. The patterns for bolts/rivets appear the same. Anyone ever change these? I also could use at least one new axle and a new set of spider gears are any of this available anymore?? I need any help for information I can get...thks for any help.. | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I do know that the 3/4 ton backing plates are interchangeable from Huck to Bendix. I have done it and have extras laying around to look at & size up. I would think that the 1/2 ton would be designed the same way. Dave | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Just cut the rivets out of the backing plate on the 50 Huck system. The collar part that is welded to the 50 housing is bigger in diameter and the 4 hole pattern is off compared to the Bendix backing plate I took off a 51 housing. I would have to enlarge the center of the Bendix plates and change the bolt pattern holes to get them to fit the 50 housing. It was close but not near a match to just bolt on. Don't want to cut the 51 backing plates to make them fit the 50 housing. Thinking maybe to use the 51 housing and put what new bearings I can get for it and change ratios but really the cost just skyrockets to do that. The only other thing is just change out the rear with an updated axle assy. If there were axles and spider gears new available and to keep it original I would do that but without a boat load of new parts it seems better money wise to update.
What is the best fit axle assy to use if I just updated the truck's rear axle?? Need some first hand advice?? Thanks!! | | |
