0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
I have been - basically - taking this truck apart down to the nuts and bolts, and cleaning/repairing/replacing what I can. Last evening, I decided to tear into the front axle. I found that the front "bushing loop" is completely gone on one set of leaf springs (passenger side). Is it feasible to replace just that spring, or should I replace the whole stack? the rest look to be in good shape......Thanks!
Is it a 1947 early that looks like the pre war ones or is it a late 1947 that looks like the 1950s models. On the late series springs are the same on 1/2 and 3/4 ton. Replacements are readily available and I would recommend replacing the pair if you want the thing to stand up straight.
