| | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 3 New Guy | | New Guy Joined: Sep 2018 Posts: 3 | Hello bolters ,
Just bought me a (bad) cab , engine with gearbox out of a 1956 gmc pickup I guess.
Since the l6 engine seems in good condition (good compression , no leaks to the coolant ) I would like to change most of the gaskets since some oil leaks are apparent.
I ve been reading and searching a lot on this forums and on the internet too, but i m una le to identify this engine?
The only stamped nr i found is behind the distributor C174099
Behind the starter motor is the casting nr 3837004 GM M (This last M is further to the right of the engine , between distributor and vent tube This M is casted in a square surround)
Behind the inlet/outlet we found a kind of "label" o E30 6 o 1 or I (??? About 4 " lower ) N (inclined about 45 degrees)
The cilinderhead outside the cover mentions 3836848 GM
Inside the cover between 1 and 2 cilinder 1
Inside the cover midst of the 5 cilinder D (inclined)
Outside the cover between 4 and 5 cilinder soms kind of "label " F o 7 o 6 o (Where the "o" stands for a kind of what looks like a cast "head of a small screw"
Sofar what concernw the engine
Inside the cab , on tfhe left door pillar we found a tag aw follows
GM OF CANADA LIMITED Made in GM CANADA MODEL 1314 SERIAL 61314607513 ENGINE C174099 BODY SERIES 2819 TRIM PAINT 5207
So it seems the cab and the engine belong together since the engine nr is the same As mentioned above , my interest goes only to the engine , since i am restoring a 1959 which had a much younger v8 engine unted the hood which replaced the original l6 Somwhere oved time. So I intend to re-swap it !
Hope sombody can help me with this issue, so that I could order the right gasket set for it !
Thanks anyway !
Greetings from Belgium !
Staf
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In the USA
3837004 was a 1956 235 block It was the first year of the “848” head, which was used through the end of production of the 235 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Staf, welcome, by the numbers it appears your engine is a 1956 Chevrolet 235, hope that helps. | | | | | Joined: Sep 2018 Posts: 3 New Guy | | New Guy Joined: Sep 2018 Posts: 3 | Hello Tim and Master Gabster
Thanks for the info I will order a 235 gasket set than !
Staf
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Staf,
Make sure it is for a high pressure 235 (most gasket manufacturers would call it 1954-1962 235). The earlier low-pressure 235 engines used different gaskets (used also on the 216s, I think). | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Welcome to Stovebolt, what are the plans for you new '56?
~Boone 1932 Confederate 5 window Sport Coupe 1936 Chevy 1/2 ton pickup 1953 Indian Chief 1947 Indian Chief 1946 Indian Chief
Collector of Vintage Indian motorcycles pre '1953
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Welcome to the forum. I want to add that the Canadian built GMC trucks were manufactured with Chevrolet drive trains so don't confuse the USA made kissing cousin GMC trucks. Vintage Vehicle Services can report production numbers, color and other specific details about your Canadain built truck if you provide them your VIN. fax 1-905-440-7644 ph 1-905-440-7636 www.vintagevehicleservices.com | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Make sure it is for a high pressure 235 (most gasket manufacturers would call it 1954-1962 235). The earlier low-pressure 235 engines used different gaskets (used also on the 216s, I think). Not that it applies here, but just to be clear 1954 engines used the same gasket as the earlier engines. The pan gasket for a 56 should fit 1955-62 235, and 1955-63 261.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
Welcome Staf. The M with a square around it means that it was cast at McKinnon Industries in St. Catharines Ontario. GM owned that engine plant for many years. | | |
