7 members (Wally / Montana, greenie-reddy, sron48, padresag, walter74, Wayne67vert, Shaffer's1950), 92 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
#128090 09/11/2007 6:17 PM
As I'm a rookie and have only been spray painting for about a year I've put my 3rd coat of paint on the cab of my 46. I wet sanded between coats and on the third coat there is a couple of blemishes or dull spots I suspect from the paint flashing or drying too quickly. To bring these small areas up to match the others would it be better to use rubbing compound or wet sand with a very fine emery cloth. I intend to put 2 coats of clear on top. Any help would be appreciated. By the way whomever invented gravity feed spray guns was a genius, what a difference from the old suction type guns Thanks
Bob T
Bob,
What kind of paint are you using?
High gloss automotive enamel finish.
Bob T
Ex Hall Monitor
Ex Hall Monitor
You'll need to wet sand before clearing anyway.
When I did mine, I wet sanded in 3 stages, starting with 1500, the 2000, then finishing with 2500 grit wet or dry automotive sandpaper. Then final buffed with polising compound.
Bill Burmeister
