| | | Forums66 Topics128,034 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | I have purchased a 1937 GMC pickup. Cool truck. I think it has an Oldsmobile engine. Casting # for engine is 414438. 6 Cly flat head. Truck Model is [u]7 14 B. Chassis # is 15628 Any help as to where to find info will be appreciated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2010 Posts: 244 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 244 | | | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | Truck is 1/2ton . I have checked with oldgmctrucks .com, but they were not much help. Casting # and SN: all stated with 1938. Can not find much with Chassis # of 15628. This is the # on the data plate mounted on the firewall inside the cab. Also model is -- 7 -- 14 -- B. Am sure it is a 1937 , Is this 7 for 37? What is the 14? & B? Also Straight Rating # 4600. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "I have checked with oldgmctrucks .com, but they were not much help "
Are you referring to Rob's website, or to the/his discussion board not being of much help? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Olds engine is a 230 or 233. Grille is different than '36 or '38, although sold date or date on your title might not reflect grille differences. I have a 2 carb. Intake manifold for your engine.
Short on legroom for normal sized person, good truck, though.
Ed
| | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | Phillip, it should have a 230 cu in Oldsmobile flathead 6 cylinder engine. The B indicates that it is a 126 inch wheelbase. There may be a plate on the floor on the passenger side with another number, but they are usually missing. That number was the cab designation (deluxe, standard) | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
