5 members (Jon G, dt235sd, 1955 1 Series, Otto Skorzeny, 1 invisible), 100 guests, and 0 robots.
Topics128,049
Posts1,055,689
#1280897 09/20/2018 12:49 PM
I have purchased a 1937 GMC pickup. Cool truck. I think it has an Oldsmobile engine. Casting # for engine is 414438. 6 Cly flat head.
Truck Model is [u]7 14 B. Chassis # is 15628
Any help as to where to find info will be appreciated.
Phillip Lott #1280899 09/20/2018 1:06 PM
Phillip Lott #1280914 09/20/2018 3:15 PM
OldGMCtrucks.com
Phillip Lott #1280960 09/20/2018 10:46 PM
Truck is 1/2ton . I have checked with oldgmctrucks .com, but they were not much help. Casting # and SN: all stated with 1938. Can not find much with Chassis # of 15628. This is the # on the data plate mounted on the firewall inside the cab. Also model is -- 7 -- 14 -- B. Am sure it is a 1937 , Is this 7 for 37? What is the 14? & B? Also Straight Rating # 4600.
Phillip Lott #1280987 09/21/2018 1:30 AM
"I have checked with oldgmctrucks .com, but they were not much help "
Are you referring to Rob's website, or to the/his discussion board not being of much help?
Phillip Lott #1280990 09/21/2018 1:37 AM
Crusing in the Passing Lane
Olds engine is a 230 or 233. Grille is different than '36 or '38, although sold date or date on your title might not reflect grille differences. I have a 2 carb. Intake manifold for your engine.
Short on legroom for normal sized person, good truck, though.
Ed
Phillip Lott #1281029 09/21/2018 11:58 AM
Phillip, it should have a 230 cu in Oldsmobile flathead 6 cylinder engine. The B indicates that it is a 126 inch wheelbase. There may be a plate on the floor on the passenger side with another number, but they are usually missing. That number was the cab designation (deluxe, standard)
1936 GMC T-14 1/2-Ton Pickup
Phillip Lott #1281030 09/21/2018 12:03 PM
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
