5 members (baldeagle, Woogeroo, Hotrod Lincoln, Otto Skorzeny, 1 invisible), 339 guests, and 4 robots.
Topics128,165
Posts1,057,087
Members48,463
Would like to know what i need to do to put a 1955 -235 in place of original 194 --6 in 1931 chevy coupe 194 has antifreeze in oil and is stuck . Would like to put a six with inserts in it
1938-46 truck bellhousing will bolt to 1931 trans and 235.
1942-54 flywheel, if staying 6 volt.
I should have documented it, but one of the two front bearing retainers from a 1938-47 truck 4 speed.
Front mount will need some modification as the 235 is about 1-3/16" shorter.
Bell-housing crossmember or the pan will need to be modified.
Throttle linkage
Exhaust.
If a 1955-62 engine is used, water pump adaption.
I'm sure there is more, but that is a start.
Last edited by Pre '68 Dave; 09/21/2018 2:42 PM. Reason: Flywheel year correction.
My Blog
“Coupe”? What kind of pickup is a coupe?🛠
A rare one
Oh you poor uninformed young people---of course there were coupe pickups. Gm made them from 1936-42. Do a search foe "pickup boxes for coupes" and then read the article by Jim Carter Truck Parts and look at the very good pictures. A good friend had a 37 Chevy business coupe with the pickup box and my Dad hauled his bulldozer service parts in an old Ford coupe with a pickup box. IIRC both Sears and Montgomery Ward offered after market ones that you installed yourself. The Aussies improved on our crude ones with their Utes.
Evan
Just cause it looks like a pig don't mean it's a pig.
I believe the flywheel would have to be later than 1940. The 1940 used 6 bolts on the crankshaft but were smaller in diameter than the later ones, I believe. Didn't the 38 and 39 use four bolts?
1951 1 Ton Completed
Thanks for catching that truckernix.
The flywheel would need to be 1942-54.
1938 and later pressure plate and disc.
It is true that 1940-41 flywheels are 6 bolt, but they are 3/8", not 7/16", that started in 1942.
The center hole that pilots on the crank is also larger than 1942-62.
My Blog
