7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
I have a 1934 Chevrolet 30 cwt or 1 1/2 ton big bolt it has a cable throttle o the dash as well as a foot throttle on the floor and a and throttle on the steering column. can some one explain why this was done the truck was shipped to Australia and the body maker here was Holden body works but i am thinking that the throttles would have been done at its build point in USA. any help would be appreciated. the motor was made on the 5th on September 1934 and was a master and truck motor
1934 1-1/2 ton truck (Australia)
Hello psmith,
Welcome to the Stovebolt site. All of the US made trucks made pretty much from the beginning of time up to the automatic choke era have both a hand and foot throttle. The hand throttle is primarily used in initial start up of the engine much like the fast idle cam on later model carburetors. The hand throttle was also used to add RPM for winching, dumping, creeping along in farm fields, or other tasks requiring a little more engine speed. I have never seen a throttle on the steering column. A picture would be great. Hopefully someone with greater knowledge of 1930's vintage Holden's can shed some light on this.
Paul
Lots more pictures
Where are you AUSTRALIA is a big country
Hi I am in Queensland just outside Brisbane towards Toowoomba. as I originally said i have a throttle cable on the dash board and there i also one for the foot accelerator but i have no idea as to why there would be three
here re photos of the upper and lower connections on the steering column
https://photos.app.goo.gl/dmEPp6mEKpjnpJ5s6
Your links don't work...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
They didn't for me either.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Didn’t work in for me in Newcastle nsw downunder
Have tried to fix link hope it works
That steering column throttle does not look like original equipment- - - -maybe it's been adapted from a Model A or Model T Ford. The notched quadrant and the lever looks identical to what's on a Model T.
Insomniac
Insomniac
Maybe an early system for handicapped driver?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Model A's used a lever somewhat like yours on the column to adjust the mixture. I haven't a clue why.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
On Model A's the left hand lever was manual spark advance (there was no centrifugal or vacuum advance) and right hand lever was throttle. The mixture adjustment was a knob on the right side below the dash that connected to a rod going down to the carburetor. It served a dual purpose of choke (pull out) and mixture adjustment (turn).
