| | | Forums66 Topics128,042 Posts1,055,597 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | Howdy stovebolters I recently bought a 1959 261 that had a total rebuild. Bored a couple of thou, new piston ,rings , bearings , and cam. I'm getting it ready to start it for the first time since the rebuild and I need to know the proper break in method. I'm been led to believe this would be necessary with a new cam and lifters .
good planning is no substitute for dumb luck
| | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | Before it even gets started, yes, it true your stock engine has very little valve spring pressure, and valve spring pressure is what kills new cams, but for the price of the break-in compared to a rebuild, it's will worth the trouble to break it in properly. Race engine are total different animal, and most procedures are geared towards them. Don't go by the shop manual either, it's 50+ years old and oils are nothing like they were when it was written.
Here is how I would do it:
1) Have a good carburetor that works and doesn't leak, full of fuel, and not brand new and untested 2) Have the coolant system full, no air pockets, new or cleaned radiator, heater core hooked up and open. 3) Have a new fuel system hooked up, fresh fuel, fresh filter. Use a jug of fuel if needed. 4) Have a fire extinguisher, garden hose, wet rag, and a few tools handy but not under foot where you trip over them 5) Have an oil pressure gauge that is accurate and mounted where you can see it at all times 6) Have an infrared hand held thermo temperature gun handy for checking temp of radiator and engine. 7) Have the engine oil system primed before trying to start the engine, DO NOT use starter to prime the oil system! 8) Have the timing set before trying to start engine, search this site for tips on setting time with out running the engine 9) Have Break-in oil in the engine, yes it cost more, but not as much as a rebuild will when the cam goes flat 10) Have a new or fully charged battery, new cables the correct size, and clean grounds 11) Have a full exhaust system installed, or quiet muffler, YOU MUST be able to hear the engine 12) Have the valves adjusted to cold spec's 13) Have some sort of tachometer installed
A) Start engine, if it doesn't fire right off, stop and check valve adjustment, fuel system, and timing. DO NOT continue to crank B) Once it starts, set rpm to 1500 to 1800 rpm ASAP, DO NOT try and tune at this point, get rpm up NOW C) Set timing as it is running by ear, advanced is better then retarded, set where it sound best, D) Monitor cooling temp, oil pressure, and general engine condition, KEEP IT RUNNING E) Use garden hose to cool radiator if needed, KEEP IT RUNNING, but keep it cool F) After 10 to 15 minutes of continuos high rpm, slowly bring rpm down to an idle G) Now is the time to set timing, carburetor, dwell H) Let idle for a few minutes to cool the engine down before shutting down
Try not to shut it down once it starts, little leaks and what not can be fixed later, if it sounds OK, keep it going. Break-in is only for the cam and lifters, rings, and bearings will need some drive time to break them in so don't change oil yet. The only way the lifter and cam contact area gets oil is from the crank throwing it around, the higher rpm insures enough is being thrown at the cam.
Options: Use the garden hose plumbed into the lower radiator hose, vary the amount of water flow to control the engine temperature, use a long upper hose to run the water away from work area. This works best if the radiator is questionable. The heater core helps pull heat out of the system, so have it open and blower running if possible. Use a thermometer in the upper hose outlet, keep in the 170 to 190 range.
| | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | Thanks Joe, I was aware of some of these procedures , but not all . nor did I know the why, but I get it now. I'll follow these steps to the letter and let you know how it goes when I'm done, probably in a week or so.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | May be obvious to some but worth mentioning.. Install a known working oil pressure gauge and check it early and often | | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | What kind of brake in oil is recommended , and how much , 50% or 100% John
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | That is almost exactly the process I use to break my motors in. As for brake in oil, for years I used regular 10W30 and a can of real GM EOS (Engine Oil Supplement). The current EOS is not the same stuff. For probably the last 10 years I have been using bradpenn break in oil. Base stock Pennsylvania crude, a synthetic package (making it a semi synthetic) and additional ZDDP for the brake in. Its one of those things, I used it the first time, the motor broke in perfectly. So I used it ever other time and same result. I used it on my own 261 (very modified motor) so I like the brad penn--its now called PennGrade after the company was purchased by the DA Lubricant folks. There are other products that is the one I like and have had the most success with recently.
Mike
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Great post Joe! I need to copy that and put it on the refrigerator with a big magnet.
| | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | Comp Cams sells break-in oil and can be sourced local. Brad Penn is excellent oil but needs to be ordered. I can get Comp Cams oil from NAPA or Orielly's, Summit racing also sells all kinds of oil. GM EOS works well, haven't bought it for awhile so maybe it;s not as good as it was. Your engine doesn't have the valve spring pressure most aftermarket cams need to work properly, so the load on the lifters and cam lobes is minimal. I would still use the break-in oil since the cam is new and you don't know how well it was ground or hardened being a low production cam. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check your nearest WalMart to see if they have Brad Penn break-in oil. | | |
