Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Peggy M, tclederman, ranchojuan, greenie-reddy, 1 invisible), 160 guests, and 6 robots.
Topics128,289
Posts1,058,583
Members48,492
I want to lower the rear end of my 46 truck and want to remove rear leaf springs and use adjustable coil over shocks. Will it work by removing leaf springs and attaching coil over shocks to axle and a added cross member or do I need 4 link set up. I only have a inline 6 so I won't be racing the truck. I don't know if this is a good or a bad idea. Never done this kind of thing before so I thought I would check with the experts before I did and wished hadn't.
It should work, but I suspect it will ride rough. If you remove leafs, keep the second longest since it's a safety in case the main leaf breaks. Can you not just install spacers between the axle and spring? I was thinking the spring is under the axle.
Are you talking about removing the leaf springs all together? If so, you will need stabilizer bars from front to back and from side to side.
Well it sounds like its not a good idea.
At one time Ride Tech was developing a rear suspension kit that utilizes a Lincoln rear suspension. I can't remember the Mark number of the Lincoln. Was to be a mostly bolt in application. Here. This is not exactly what I was looking for but you might contact them. I read about it 25 years ago in a truck magazine and called them but they said then that it is not ready yet.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
You could remove leafs uses the two top for axle placement, then add air bags for actual load control. It's the same idea as coil overs only you have more control over the ride and height. I would talk with a spring shop before proceeding, they may have a better option then removing leafs.
Yes, such a modification might be possible, but the burning question would be "Why?" You'll be turning a pickup into a Cowboy Cadillac that probably won't be able to carry any more load than maybe hauling a Yeti cooler to a tailgate party. More likely, the unfinished project will stall, and yet another good truck will end up gathering dust for the next decade or so. A lot of other ones go that way, where a vast project was the victim of half-vast planning. Make it work on paper before you modify anything.
