9 members (Wally / Montana, UtahYork, Frank50, BarryP, BC59, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible),
125
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 30 | After pb blasting..heating and drilling out rusted bolts I have one left to fix. The front end top shackle spring pin with grease fitting on passenger side wouldn't budge with an easy out and heat. I decided to drill out and hopefully run thread chaser thru. I took pin into couple places to get correct thread and size. They were not much help and told me must be an odd size thread. Has anybody had to run a thread chaser thru the pressed in threads for top shackle spring pin? I did a search and only saw that 3/8ths 24 was used for the grease zerk but saw nothing what would be used for chasing spring pin out. Could some on chime in on maybe where to find proper size as I don't see it covered in my assembly manual..just replacement part number for whole frame bracket. Auto zone guess was 3/4 10. I think thread size is wrong. Any ideas ? Thanks in advance luv this site. Jeff | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't believe the threaded shackle pins and bushings are a common size or thread profile. The good news is the bushings press out of the brackets in the frame (and spring eyes) and new bushings with pins come in the replacement shackle kits. Picture and part numbers here and following pages http://chevy.oldcarmanualproject.com/parts/1929_54/432.htmNew parts can usually be had at NAPA or other auto parts stores, spring shops, or the usual restoration parts suppliers. | | | | | Joined: Jun 2018 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 30 | Grigg thanks so much! I'm on it. | | |
