2 members (klhansen, 1 invisible), 151 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1280451 09/16/2018 6:27 PM
diesel weasel
diesel weasel
1952 6400 parked in the late 90s.
After getting a clear title in hand, I aired up the tires and drug it a couple miles down the road to my shop. Gave it a quick pressure wash inside and out. I could grab the fan and roll the engine over with relative ease. Next I pulled the valve cover and gave everything a thorough spraying of MMO as I turned the engine over by hand. Then gave a soaking of penetrating oil to everything I thought I may work on in the near future. I pulled the interior and gas tank and removed the bed.
Plan of attack
Get this engine running
Get brakes(which previous owner mentioned were problematic)
Check clutch, transmission, & rear end
Deal with tires and rims
Stay tuned for updates and progress pics.
As bought:
[img]http://i.imgur.com/9D4Khld.jpg[/img]
Sharp knives
Accurate Rifles
Smooth Whiskey
I have one exactly like it! Parked in 1996. How do I connect so I will get updates to this thread? I'm sure I've done it before, just don't remember how. I have my brakes off, but I'm unemployed at the moment so can't afford to finish. I pulled the interior, gas tank, put on 19.5 inch wheels (though I hope to find some 22.5 when I can afford it) and I have the materials to reinstall the tank and redo the seat. Motor turns, a little tweaking and it will start and the tranny seems to be good.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
diesel weasel
diesel weasel
I’m new here and haven’t figured out all the forum tricks yet, but I’m glad to have you along in this thread. What 19.5 wheels did you get?
Sharp knives
Accurate Rifles
Smooth Whiskey
Oldie, click on your username at the top of the page. Go to preferences and you can watch any thread you want. 🛠
diesel weasel
diesel weasel
Well the fuel pump was froze as was the starter. Starter was taken off and tapped on and boosted until it began working freely. Fuel pump was well as all lines and inline filter were replaced, local NAPA had what I needed on the shelf. After some encouragement she will turn over crank and purr like a kitten.
Here are current pictures as it sits:
https://m.imgur.com/a/X1jA4zF
Sharp knives
Accurate Rifles
Smooth Whiskey
Big Bolt Forum Moderator
sweet ride, nice place to work with a pit to drive it over!
Mike
diesel weasel
diesel weasel
Thanks, the pit is a must for maintaining our farm equipment and 18 wheelers.
Sharp knives
Accurate Rifles
Smooth Whiskey
diesel weasel
diesel weasel
While bleeding the brakes I managed to blow out 2 lines, so I changed them all(all that were left anyway, the previous owner abandoned the front brakes at some point). So once I got the new lines ran I went to bleed again and the Master cylinder starts hemorrhaging, guess it’s time to order one.
Napa shows it as a 9220 and RockAuto comes up with a 9221, I cannot make out any useful casting number on the MC itself. Once I install the new MC I’ll go ahead and blow out the wheel cylinders next...
Sharp knives
Accurate Rifles
Smooth Whiskey
Nice job on the pics and good to see your work progress !
Did you replace the brake rubber hoses and does your truck have a hydrovac?
I have often taken those MC's out and disassembled and checked their cylinder bore for wear. The port in reservoir often also needs cleaning, and others here can tell you if a basic MC rebuilt kit is still available. I have not yet had to re-sleeve one of those bigger MC's , but that is an option if you can't find a new one.
diesel weasel
diesel weasel
Yes it does have a hydrovac system, I have not replaced any vacuum lines on the system. I’ve replaced every line from the MC to the rear wheel cylinders. I gave some thought to a rebuild kit but it seems a new one from RockAuto isavaliable for $130, I’ll give it a try.
Sharp knives
Accurate Rifles
Smooth Whiskey
I also would like to know what 19.5 wheels you used. been trying to find a more practical solution for my '47
Logan
2010 Silverado 2500HD
1947 GMC 300
