| | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 759 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 759 | I feel pretty stupid about this, BUT, the pictures that I took during disassembly of my differential don't really show the direction of the pinion ring on the pinion shaft. I made a note that my punch marks go a certain way. Problem is, I apparently forgot to actually put any punch marks on it. I'm talking about the large ring that flops around loose on the rear end pinion shaft when it is out of the truck. The ring that the 3 differential retaining bolts tighten up against. I think that the beveled edge goes toward the pinion gear, (away from the splines), so that the retaining bolts push it up against the thick double row front bearing when the outside retainer bolts are tightened. I am putting this back together and just want to confirm that my thinking is correct. Thanks, Mike
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Best off if you post what truck you're working on. Year size.......
Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Aug 2018 Posts: 759 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 759 | You're right, but I figured it out, so just disregard.
