7 members (HandyAndy, MickeyP, Gdads51, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible), 60 guests, and 1 robot.
Topics128,049
Posts1,055,699
#1280105 09/13/2018 3:48 PM
I feel pretty stupid about this, BUT, the pictures that I took during disassembly of my differential don't really show the direction of the pinion ring on the pinion shaft. I made a note that my punch marks go a certain way. Problem is, I apparently forgot to actually put any punch marks on it. I'm talking about the large ring that flops around loose on the rear end pinion shaft when it is out of the truck. The ring that the 3 differential retaining bolts tighten up against. I think that the beveled edge goes toward the pinion gear, (away from the splines), so that the retaining bolts push it up against the thick double row front bearing when the outside retainer bolts are tightened. I am putting this back together and just want to confirm that my thinking is correct.
Mike
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Best off if you post what truck you're working on. Year size.......
Don
Can’t begin to tell you how much I hate the name Stovebolt.
You're right, but I figured it out, so just disregard.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
