Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1279970 09/12/2018 1:19 PM
good morning to all,
we have been working on my sons 1953 chevrolet canopy it has a 250 motor in it. the gas tank has been cleaned out, new gas lines, new fuel pump, two gas filters added, rebuilt carb, new pipes, new spark plugs with points and condenser replaced. when i drive the truck, runs fine now but when i get home and turn it off, the motor "diesels" in other words it still wants to run
any ideas? thanks in advance
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
oldmemoriescc #1279976 09/12/2018 2:17 PM
Timing and/or you have the idle set too high.🛠
oldmemoriescc #1279977 09/12/2018 2:18 PM
H Online: Content
Check for vacuum leaks, and slow the idle speed down. 500-600 RPM is a good target to shoot for.
oldmemoriescc #1279979 09/12/2018 2:25 PM
3B Offline
Hy oldmemoriescc, what r.p.m. is the engine idling at? The throttle may be open too far at idle allowing the engine to get air after you turn the ignition off, the engine may have carbon deposits in the combustion chamber that remain hot enough to ignite fuel if there is air (oxygen) present. Hope that helps.
oldmemoriescc #1279991 09/12/2018 4:19 PM
Moderator, Electrical Bay
When ignition switches fail, occasionally they won't immediately break the circuit which keeps the coil energized when you turn the key off. This will cause a condition which almost exactly mimics dieseling because usually the engine will run for another 5 to 10 seconds before the ignition switch contacts can "let go."
The 250 sixes had HEI ignition...or at least I know for a fact some of them did. If a relay wasn't added between the heavy gauge wire needed to supply the coil then that could definitely cause the ignition switch to fail. And I am a shining example of this oversight. I recently added HEI to my 235 and forgot all about the high amp demands of the HEI coil.
So now I have to wire at least a 20 amp relay (preferably 30) connecting the 10 gauge coil wire straight to the battery (the ignition switch will then be operating that relay in the same manner it operates the starter solenoid). Otherwise my engine will continue to run every time I turn it off until the ignition switch finally burns out.
As I recall the original switch was designed to handle a maximum of 15 amps and with the HEI coil that isn't enough. And yes, I am irritated that I made such a boneheaded error, but I did and now I know. Good luck on your search of the problem. One way to check for this is to (a) find the coil (some were mounted on the engine) and (b) have somebody turn the engine off at the same time you disconnect the plug from the coil. If it stops without continuing to run, you've found the culprit.
~ Jon
oldmemoriescc #1280004 09/12/2018 6:21 PM
Sir Searchalot
Sir Searchalot
Agree with others. Idle too high.
To test the switch, just pull the hot wire off the switch to stop motor.
oldmemoriescc #1280117 09/13/2018 4:55 PM
Crusing in the Passing Lane
Engines will also backfire when going downhill(throttle off) if there is an ex. Manifold leak.
Ec
