4 members (Bill Hanlon, pauld, Pre '68 Dave, 1 invisible), 72 guests, and 5 robots.
Topics128,268
Posts1,058,394
Members48,485
#127970 09/01/2007 10:06 PM
Red dot, center of chest ...
I'm doing some major work on my truck. I've got the doors completely disassembled and the hinges removed. The left side hinge has a spring in it and a detent, so it will stay open when you open it. The right side door hinge does not - the slot the spring fits through isn't even there so it looks like that was how it came from the factory.
This is a '48 1/2 ton pickup. Is that normal?
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#127971 09/01/2007 11:02 PM
JFO Offline
Can you send me a picture of the left hinge. I have my right upper hinge apart. I could send you a pict of it (from a 49 3/4 ton but I think the hinges are the same).
#127972 09/02/2007 12:22 PM
The master parts catalog seems to infer both doors have the springs. On 1947 models, the catalog specifically says right and left springs, but with 48 and up models, it just says "ALL". My 49 has springs on both doors.
'50, 3604 just replaced them, both doors, left and right springs.
Denny G
Denny G
Sandwich, IL
