0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | I'm doing some major work on my truck. I've got the doors completely disassembled and the hinges removed. The left side hinge has a spring in it and a detent, so it will stay open when you open it. The right side door hinge does not - the slot the spring fits through isn't even there so it looks like that was how it came from the factory.
This is a '48 1/2 ton pickup. Is that normal? | | | | | Joined: Aug 2004 Posts: 9 New Guy | | New Guy Joined: Aug 2004 Posts: 9 | Can you send me a picture of the left hinge. I have my right upper hinge apart. I could send you a pict of it (from a 49 3/4 ton but I think the hinges are the same). | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | The master parts catalog seems to infer both doors have the springs. On 1947 models, the catalog specifically says right and left springs, but with 48 and up models, it just says "ALL". My 49 has springs on both doors. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | '50, 3604 just replaced them, both doors, left and right springs. Denny G
Denny G Sandwich, IL
