0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1277115 08/21/2018 2:21 AM
The linkage arm for the clutch pedal rod is bent and cracked for my step van. The arm was bent in a S shape to reach directly over to the clutch rod. I'm not sure if the arm was bent and rigged that way or if another linkage rod was used in conjunction originally. I can find no pics or diagram of COE type setups for 1958 trucks/step vans, let alone a replacement arm. Does anyone know of the correct setup for these or have a pic or parts source? Thanks.
1958 Chevy Grumman Olson step van
I had a friend repair the arm, as I could not find a replacement.
I found a replacement but the rod is too far from the clutch linkage arm. I saw a diagram with a rod hook in between the arm and off set rod. I'm wondering if mine was missing it the whole time. I'm not sure if it's that or a longer rod or fork is needed. Does anyone know if the hook was included on all these clutches or if the arm should attach directly to the clutch rod?
Well if anyone else needs this info, yes, there is an extra rod in the linkage that is required.
The part shown is a common part of the clutch linkage in pickups through 59. They likely didn't change anything for your series truck.
Fred
Fred's correct, the Forward Control Chassis takes the same Link as the pickup trucks (7" long Eye Hook, p/n 3676454, used from 1947-59).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
