| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 54 | I had a differential from a 46 Chevy half ton that was seized solid from sitting in water. A couple of months ago I submerged it in my farm dugout and just last week I retrieved it and was able to salvage the axles and crown and pinion. Small diameter bolts that would have twisted off came off easily, I was able to remove the bolt and drive the pin that holds the spider gears together out with little effort. I only want to use these parts for spares as the ones in the truck I am restoring are good. I have used this method on tools that are seized as well. It isn't a quick fix as I usually leave them in water for a couple months but it does work. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I had always heard that, although I've never tried it. The saying was that "water is what formed the rust, water will dissolve it". | | |
