5 members (MRMEROTH11, Eisenholtz, TexasA&M48Truck, Wickedbass, Gdads51), 66 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
I had a differential from a 46 Chevy half ton that was seized solid from sitting in water. A couple of months ago I submerged it in my farm dugout and just last week I retrieved it and was able to salvage the axles and crown and pinion. Small diameter bolts that would have twisted off came off easily, I was able to remove the bolt and drive the pin that holds the spider gears together out with little effort. I only want to use these parts for spares as the ones in the truck I am restoring are good. I have used this method on tools that are seized as well. It isn't a quick fix as I usually leave them in water for a couple months but it does work.
I had always heard that, although I've never tried it. The saying was that "water is what formed the rust, water will dissolve it".
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
