8 members (Rusty Heaps, Frank50, BarryP, UtahYork, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible), 138 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
I've struggled with this for a couple hours, trying several different things, with no luck. Time to ask for experienced help.
My SM420 is completely torn down, except for the reverse idler shaft, which I cannot seem to get out. The Novak directions say to drive in the retaining pin, after which the shaft can be driven out from front to rear, using a brass drift. I'm confident I have the retaining pin completely inside the shaft, but I can't get the shaft to budge. I'm about to use my press, but don't I want to break anything. Anyone else have the same problem? How did you get yours out?
Thanks in advance.
Rear view of shaft & retaining pin
Front view of shaft
Internal view of idler shaft
Greg Brown
Hi Greg, I've been inside a few of these as of lately.
On one of the rebuilds I did, I had to break the shaft loose with my 20 ton press. Just make sure the retaining pin is driven clear of the case.
Your in the PNW, pm me with your tel number and I can help in any way.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Steve,
Thanks much for the guidance. I carefully used my press today on the shaft, with success!
Greg
Greg Brown
