6 members (Bill Hanlon, Leo, GMCJammer51, Phak1, Tom McGrath, dt235sd), 105 guests, and 2 robots.
Topics128,050
Posts1,055,646
Hey all,
I recently bought a 56 3100 to restore. I removed the entire bed of the truck and discovered the rear msot crossmember of the frame was badly bent. Honestly, I have no clue how it could've happened. It almost looks pinched. The bed was all original and in fine shape.
Anyhow, does anybody know where I could source a new crossmember? It appears it's as simple as drilling out the rivets and bolting on a new one.
Thanks!
56 Chevy 3100
That damage was caused by towing another vehicle with a chain wrapped around the crossmember. There's no need to replace it- - - - -a good body/frame man can straighten it in about 10 minutes with a rosebud tip on an acetyline torch and a big crescent wrench to use as a bending tool. These old frames are mild steel- - - -heating and straightening them doesn't compromise the strength of the metal like would happen with a newer frame.
Wow. Look at the brain on Jerry! Thank you! I'll look for somebody who can assist.
56 Chevy 3100
Otherwise leave it. You never know when you might want to tow somebody again!! grin grin not me
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
We do them as Jerry described but found it helps to set a Port-O-Power between the rails and GENTLY apply pressure while heating with the rosebud. The guys are really good with heat and metal and sometimes use two rosebuds and "walk" the bent piece back into shape. Have someone on the Port-o-Power valve at all times because the metal doesn't know when to STOP moving.
Evan
