6 members (Charles in CA, lumbersawyer, Rustnut, Hotrod Lincoln, Donf, 1 invisible), 64 guests, and 4 robots.
Topics128,203
Posts1,057,414
Members48,471
I had to install a hydraulic throwout bearing for my 58 (76 350 SBC0 2 ton truck, but since I installed it, it keeps chewing up my bleeder hose. The problem stems from the fact that they attached the bearing to the body, not the ram, so when I push on the pedal, the hoses are shoved into the clutch, damaging them.
I am looking for a stationary body Throwout bearing that can fit a stock clutch affair. Any one here know of a good one?
H Online: Content
I have always been of the impression that RAMs don't work with a stock clutch, Maybe I was mistaken? the description doesn't say, instead it describes a clutch. have you worked with these styles? is the bearing attached to the ram, not the cylinder?
H Online: Content
The illustration shows the pressure line and the bleeder attached to the main housing, which bolts to the bearing retainer. You might want to give JEGS' technical department a call to see which clutches that one will accommodate, or maybe they can suggest an alternative. I used to do a lot of business with them when we ran a round track car- - - -not so much recently.
