2 members (Phak1, dt235sd),
92
Mod | | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | I am re-using the cross pins in the rear shackles, but the small retaining pins are shot. Where can I get JUST the retaining pins? -OR- Is there an "updated" cross pin (bolt) that can be used, that doesn't use the retaining pins? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I was able to get one retaining bolt at NAPA after stripping a new one. I’m not sure if they were doing me a favor or if they have a part number for just the bolt.
When installing line up the spring pin best you can then set the lock bolt with a hammer and punch. Nut and lock washer are to keep it from falling out, the pin is soft and likely to strip if using nut to draw it into place. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I got some at Napa. Expensive and had to ship but they have them. May have an extra leftover if you confirm size. My suspension is mid 60s but maybe the same bolt. | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Thanks! I live about 40 miles from the nearest NAPA.....I will have to check the next time I go that direction! I will check on the size, but they are APPROX 2 1/2" long, 3/8" diam, and have 1/4' threads.... | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Like I said....APPROX...... I was just guessing, since I didn't have it in front of me. | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Also, a couple of my shackles had gr8 bolts through instead of the tapered lock pins....They seemed to work for about 30 years, just wondering why they need to be the OEM lock pins....I have new pins now, but was just wondering...
