3 members (Nick in Manitou, UtahYork, TooMany2count), 90 guests, and 5 robots.
Topics128,109
Posts1,056,240
Members48,437
#1278111 08/28/2018 2:29 AM
Crusing in the Passing Lane
On my '54 GMC 630 gasser(503) , I was able to get new brake cylinder cups, I had already found master cylinder(1.5") cups on eBay. My truck('54 GMC fire truck) has Type FR-3 rear brakes. They may be identified by 2 wheel cylinders, served by 2 brake lines from a 'Y' at the first cylinder, adjustment by 3/8" Allen wrench, two locations.
Upon disassembly, the wheel cylinders are identified by casting number: FD 9572; 1.875" ID. These data are from disassembly, they do not appear anyplace else, certainly not by looking under '54 GMC, forget about going that way.
My wheel cylinders were labeled 1 7/8, which is 1.875". I found on:
Powerbrake-drivetrain.com, new cups which I received today, verified, 1 7/8" , so I am all set. Of course I need to hone the cylinders, etc.
They have other associated items, too. Ah, for air brakes!!
Good luck,
Ed
EdPruss #1278137 08/28/2018 10:55 AM
V
V Offline
Once again , thanks for the info Ed. I'm going to be tearing into my brakes in the next week or two. Very timely info for me.
You've been a big help.
Tyler
EdPruss #1278202 08/28/2018 11:48 PM
My brake shoes are Wagner FF 3144, as yours might be. They are obsolete, so be gentle with yours. Do not tighten the Allen wrench to tighten the brakes too much, the innards are fragile.
Ed
EdPruss #1278534 08/31/2018 12:55 AM
V
V Offline
That's good to know and I thank you once again, Ed.
I need to get my seat recovered, I understand that the cabs on the 630 series are the same as the pickup so I'm guessing that the seats would be the same also? Going to need an oil pan gasket also. Is there anything available that will work?
Tyler
EdPruss #1278549 08/31/2018 2:29 AM
Probably no oil pan gaskets, but possible to make. Why do you need to take your pan off, unless for oil leaks?
Ed
EdPruss #1278581 08/31/2018 11:34 AM
V
V Offline
I would just like to clean it out. I imagine it's never been off and there's probably a lot of sludge build up from over the years that I'd just as soon not be contaminating fresh oil. Probably just make a gasket, like you suggested.
EdPruss #1278985 09/04/2018 9:45 AM
V
V Offline
Ed
Sent you a private message.
Tyler
