1 members (Hotrod Lincoln), 92 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
I'm in the midst of a steering upgrade on my 46 and I can't find a machine shop with any tie rod reamers. I bought tie rod ends suggested in the forum, one has a 10 degree taper and the other a 7 degree taper. I really don't want to spend $160+ for the reamers but after calling several machine shops I've yet to find one with the reamers to do the job.
I live near Upper Marlboro, MD and would appreciate advice on a machine shop that would be able to ream the pitman arm and steering arm or if anyone wants to loan/rent/sell a 7 and 10 degree reamer I would appreciate that too.
Thanks for any help!
Dave
H Online: Content
You don't need a reamer- - - -the taper can be bored on a lathe by any machinist worthy of the name. How long are the steering arms that need to be modified?
I am actually trying to replace the original drag link with a more modern setup and that's where the tapered tie rod ends enter the picture. The parts that need a reamed hole are the pitman arm and the link arm (the two pieces the drag link connects). I am not sure this could be done on a lathe.
H Online: Content
I have done many similar things while building round track race cars. The only limiting factor is the radius the lathe can swing and the machinist's imagination.
I have a 1.5”/ foot taper reamer for ball joints and similar. It is 7/16” on small end, and 1” on large.
That works out to 7.125* Not sure if your 7* spec is rounded from an inches per foot taper, the more common description for these things.
I don’t mind loaning it locally if it returns in a timely fashion and undamaged.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Jerry and Grigg. Grigg, I will send you a PM.
H Online: Content
Speedway Motors has both reamers- - - -$79.95 for one and $89.95 for the other:
https://www.speedwaymotors.com/Speedway-Tapered-Ball-Joint-Reamer-7-Degree,2918.html
https://www.speedwaymotors.com/Speedway-Tapered-Ball-Joint-Reamer-10-Degree,29005.html
Dave,
I have an old reamer I believe is 7*, range is 3/8" to 1". It not new and I don't know how sharp it is. I'm about 40 min south of Upper Marlboro...bring your parts down and we can give it a try.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thank you Jerry. It may not come to that as Mike B has offered to lend a hand.
David
Mike, I sent you a PM.
Thanks, David
Moderated by  Bill Marlow, SWEET
